13 Users Online (11 Members):
Forums >> Community >> Newbies >> External Cladding Layer over floor
4 Posts No Rating |
Hi, I am new to Revit Architecture 2008. Was wondering if someone could guide me as to how you would go about extending the external finish layer down over the end of the floor system so the material would show up in the elevation views and not the edge of the floor instead. I am generating a raised floor system on columns and have extended the floor system through to the external face of the wall core layer. I would like to be able to drag the external wall layer of the wall over down to cover the end of the floor but still keep the wall resting on the top of the floor. I know the easy way out is to extend the whole wall down to the underside of the floor, but I was trying to avoid this if possible. Chris
this has been covered in other threads but here goes....modify the wall family. edit the structure, then expand preview, switch to section, zoom bottom of wall, click modify, click the bottom of the wall, unlock the parts of the wall you want to extend. back in the model, cut a section of the wall(s) and extend. If your floor extends all the way out you willl probly want to edit the floor edge. good luck John
4 Posts No Rating |
Thanks for the help. I am sorry for the inconvenience of having to repeat yourself, but it can be difficult finding the previous threads which are of help to me. Once again thankyou.
no problem. that's what the site is for. good luck.
Timber External Cladding BOard / Weather Board |
Wed, Mar 31, 2010 at 10:02:29 AM
cladding |
Thu, Jul 28, 2005 at 4:19:11 AM
Help with wall cladding |
Mon, Jul 14, 2008 at 10:05:26 AM
Dividing an external wall into different parts per floor |
Fri, May 12, 2017 at 3:46:57 PM
exterior cladding |
Wed, Mar 19, 2008 at 6:11:26 AM
