8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Linked door schedules issue
We use a compposite file to link several wings of a campus together and in the composite we generate all of our sheets and schedules. Normally this hasn't been a problem, however I have several doors that aren't picking up the correct 'To Room' data. I went back into the linked file and selected the proper room from the drop down menu in that door schedule, saved to central and reloaded the link. I thought for sure this would fix the problem, but it didn't. This is mainly on the exterior doors but also occurs on un-named rooms like closets, and rooms with doors that swing into corridors. I suppose I could duplicate the rooms on the other side of the doors with room separation lines, but that's an ugly work-around. Is there some way to get the door schedule to appear correctly without a bad work-around? Thanks, Gyv
Edited on: Tue, Mar 25, 2008 at 3:08:16 PM
1 Posts No Rating |
I'm going to bump this year-old thread because I have basically the same problem and no good workaround. Basically, doors from the linked file can't detect their to:room, from:room, etc information.
Linked Door Schedule Problems |
Fri, Jul 4, 2008 at 3:37:38 AM
Door Schedules - Revisions |
Fri, Nov 12, 2010 at 4:10:09 PM
Linked Revit Door Schedules not showing any data Revit 2015 |
Mon, Aug 3, 2015 at 12:07:22 PM
Linked Door Schedules |
Thu, Nov 15, 2012 at 7:13:26 AM
Schedules: Ie Door schedules! |
Fri, Jul 11, 2014 at 2:58:22 PM
