Forums >> Revit Building >> Technical Support >> Fireplaces do not display in any views except 3D
Wed, Mar 16, 2005 at 10:20:23 AM | Fireplaces do not display in any views except 3D
jmsmith33
I have loaded a few fireplace families from the Revit Web Library. However, when I go to place it in my Level 1 plan, it does not appear. I can only see it when I switch to 3D view. Does anyone know the fix for this? Thank you in advance.
Wed, Mar 16, 2005 at 1:16:02 PM | RE: Fireplaces do not display in any views except 3D
aabrmn
try and open the fireplace family, select and check the visibility of the actual fireplace 3d object (visibility button in the options bar). you can also draw symbolic lines and they will appear in the plan view, this way you will have better control on the lineweight and linetype of individual lines. I hope this helps.
Fireplaces in section
Tue, Nov 1, 2005 at 7:01:47 PM
Fireplaces
Thu, Nov 2, 2006 at 12:49:50 PM
display of families in different views
Mon, Oct 19, 2009 at 9:15:23 AM
11
Fireplaces
Wed, Feb 16, 2005 at 1:42:40 PM
Grids at an Angle in Plan don't display in Elevation
Thu, Apr 26, 2012 at 2:44:38 PM
Page generation time: 0.6543
