22 Users Online (20 Members):
Forums >> Revit Building >> Tips & Tricks >> Elevation Problems
4 Posts No Rating |
Hi everyone - Having problems with getting a decent print from Revit Building 8.1 for elevations. The windows i've put in are the basic family windows, modified w, h and l. I'm looking for some help on how to tone some of the detail on the windows down a bit so they print with less thick lines. I'm also looking to add extra mullions to windows that are in the family. I'd like to make a 3 casement window with mullions splitting the end casements into 1/4s. If anyone could give me some help with this it would be greatly appreciated. Cheers!!
----------------------------------- www.shewt.co.uk |
As far as lineweights go, mess with the object styles. In Object Styles, under windows you will have the choice to change the line weight of the various components. As for the casement, read through the array function in the help file. Array works the same way in the family editor. However, once you make the array. The muntins should be equally spaced when the width changes if everything is constrained properly. Not sure if that was what you were looking for. HTH
**Using Revit Architecture 2009, 2011, and 2012** |
Revit Strucure 2009 spot elevation problems |
Fri, Jul 25, 2008 at 11:48:29 AM
Dependent elevation view problem |
Wed, Oct 10, 2007 at 7:44:30 AM
Massing printing problems |
Tue, Feb 9, 2010 at 8:11:10 AM
View range in an elevation |
Mon, Dec 17, 2012 at 11:27:34 AM
Problems tagging wainscottting wall sweeps |
Wed, Jun 20, 2012 at 2:34:37 PM
