Forums >> Revit Structure >> Technical Support >> Locking View Titles
Tue, Mar 25, 2008 at 5:56:30 AM | Locking View Titles
pdoug
3 Stars: 2 Votes
Hello all - I am new to Revit Structure.  I am having trouble with view titles.
Is there a way to lock the position of the view title after placement, then be able to adjust the viewport location?  It seems it has to be the other way around, as when I move the viewport, the view title moves with it.
I apologize if this has been asked before - I tried searching thru the forum for an answer prior to posting, but haven't been able to locate this topic.
Thanks for your help!
Tue, Mar 25, 2008 at 6:06:03 AM | Locking View Titles
You have the process right - locate the view then adjust where the title is.  With the view and view title, REVIT will give you automatic alignment lines that will help you.   When you get used to it, you'll find it works very well.
Turn off view titles
Tue, Jan 9, 2007 at 4:29:12 PM
MULTIPLE VIEW TITLES
Thu, Jan 31, 2013 at 5:46:51 AM
Right Align View Titles
Mon, Jan 28, 2008 at 3:57:58 PM
VIEW TITLES
Mon, Jun 18, 2018 at 10:24:52 AM
View Titles problem
Mon, Aug 25, 2008 at 10:42:35 AM
Page generation time: 0.6796
