Forums >> Revit Building >> Technical Support >> Linking files best practice?
Mon, Mar 24, 2008 at 4:46:47 PM | Linking files best practice?
eltazar
Im begining a project that has two residences on the single lot using revit 2008. I understant that it is best to create a site file and seperate residence files and link them into the site. This is my first linked project and my questions are:
1. is it best to create each residences as a model with all anotation and elevations and sections etc or do you create the model and place anotation later.
2. is it best to do elevations in each residence file or are they best done on the site file into which the residences are linked.  If you do elavtions in the indvivdual residences how do you place the ground lines when the topography is in the site file?
 Any other advice would be helpful
Tue, Mar 25, 2008 at 6:21:37 AM | Linking files best practice?
I would do all of the documentation, views, sheets in each residence file and only link in the site.
Tue, Mar 25, 2008 at 3:06:35 PM | Linking files best practice?
eltazar
Thanks. How does that work with the ground lines which are taken from the site topography? Is there a way to import these back into each residence?
Tue, Mar 25, 2008 at 3:56:11 PM | Linking files best practice?
The site model topography will show in all views it is linked to.
Linking Revit Files for Sheet Coordination
Fri, Jul 10, 2009 at 11:09:09 AM
Linking large files
Wed, Aug 31, 2005 at 2:32:01 PM
Linking Revit Architecture files
Sun, May 12, 2013 at 11:05:15 AM
Linking Models
Wed, Mar 5, 2008 at 3:22:34 PM
dividing project and linking files : structure, interior/envelope walls
Wed, Apr 6, 2005 at 6:22:48 PM
Page generation time: 0.8577
