Forums >> Community >> Newbies >> my first reflected ceiling plan
Mon, Mar 24, 2008 at 2:20:28 PM | my first reflected ceiling plan
mpp0117
I am getting ready to start my first reflected ceiling plan in Revit. It is for an existing building with 99% of the ceilings will be the existing floor / roof structure exposed. To make things more complicated, the existing floor / roof construction is a mix of different types of materials… for example: the second floor construction is made up of existing exposed concrete in some areas, existing exposed wood decking in some areas, & existing steel decking in other areas… and is supported by existing steel beams. What is the best way to do a reflected ceiling plan showing these existing conditions and new lighting we will be adding? Should I make different floor types? Anyone know of a good tutorial for this?
Reflected ceiling plan
Fri, Mar 28, 2008 at 11:16:26 AM
Cannot open reflected ceiling plan
Fri, Jan 9, 2009 at 2:23:07 PM
Problem seeing doors in reflected ceiling plan
Mon, Jul 14, 2008 at 9:26:12 AM
REFLECTED CEILING PLAN
Thu, Jan 20, 2011 at 3:12:51 AM
Different Plan Title for Reflected Ceiling Plan
Mon, Aug 1, 2022 at 4:28:33 PM
Page generation time: 2.7125
