Forums >> Revit Building >> Technical Support >> detailed wall sections
Mon, Mar 24, 2008 at 11:11:04 AM | detailed wall sections
ljromero
im using Revit Architecture 2008.  How do I get detailed wall sections? I cut a building section and added a wall section, but it doesn't have the level of detail im used to.  Do i draw the detail using the detail lines or is it a type of component I need to add?
Mon, Mar 24, 2008 at 12:24:05 PM | detailed wall sections
Don't expect the program to do everything for you.  It will keep track of all of the major components but you add the details.
First, change the detail level to medium or high.  You can edit the cut profile of your components like walls to add returns at window jambs... heads or as you need to.  Use detail components like metal/wood studs, masonry units, bar/wood joists as well as detailed window / door components that you may have to create.
Thu, Mar 27, 2008 at 2:10:16 PM | detailed wall sections
ljromero
oh ok I got it. Thanks for the help
Detailed section elements
Tue, Mar 16, 2010 at 3:13:53 PM
Calling Out a 2D Detailed Section
Mon, May 15, 2006 at 8:09:44 PM
Sections, different level/views
Sat, Aug 5, 2017 at 7:34:44 AM
From Wall Sections to Drafting Views
Fri, Sep 25, 2009 at 10:22:08 AM
Wall Sections disappearing?
Tue, Aug 21, 2007 at 1:13:29 PM
Page generation time: 1.5056
