Forums >> Revit Systems >> Technical Support >> Cabinet Files Installation Error while installing RAC 2008
Sat, Mar 22, 2008 at 1:49:13 AM | Cabinet Files Installation Error while installing RAC 2008
amitjersy
After accepting License Agreement, When I press Install button to install the "Cabinets File" then "Content Extraction Dialog" reports the following errors abut errorneous cabinets, Pressing Skip or Retry doesnt solve error: -
Error: The data is invalidChoose to Retry to skip Cabinet "C:\Document\Amit\Locals\Temp\ENUHelp.cab"
When I press Skip, then other error appears: -  Error: The data is invalidChoose to Retry to skip Cabinet "C:\Document\Amit\Locals\Temp\IntMetTempl.cab"
When I cancel Cabient installation process then, a dialog appears that RAC 2008 is successfully installed but when I run the application then it give error that - "AccuRender rendering feature is not available because the Accurender library could not be found on your computer. Please check the AccuRender resource path set in settings> Option dialog"
After it another error appears that the default template file specified in the "File Location" section of the> Setting>Options Dialog (C:\Document & Settings\All User\Application Data\Autodesk\RAC 2008\Metric Templates\DefaultUs-Canada.rte) does not exist. Other error appearas that: - Some of the Revit Content that you chose to install was not successfuly installed, do You want to try and install the content again. When I press Yes to install the require content then the same error occur that: -
RAC is installed porperly but except the Templates & Cabinet files. I checked in RAC 2008> Settings>Options>File Location>Default Template File then Press Browse for looking of defaultUS-Canada.ret, But this template is not exist.Pls tell how to install cabients file without any error.
Trouble Installing RAC 2010 x64
Thu, Oct 1, 2009 at 3:47:49 AM
problem installing
Tue, Apr 19, 2011 at 3:23:12 AM
REVIT MEP 2012: Installation problem-Error 2343.Specified path is empty.
Fri, Apr 29, 2011 at 7:30:51 PM
Error in RAC 2008-HELP ME
Tue, Dec 11, 2007 at 12:52:17 PM
Error in RAC 2008
Mon, Dec 10, 2007 at 12:46:32 PM
Page generation time: 0.4296
