Forums >> Revit Building >> Technical Support >> Sidewalks that curve no change in grade
Thu, Mar 20, 2008 at 2:38:18 PM | Sidewalks that curve no change in grade
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
A simple curved sidewalk can not be sloped the option to adjust edges is not available. Pretty weak.
Sat, Mar 22, 2008 at 12:15:19 AM | Sidewalks that curve no change in grade
MazterMind3212333
3.5 Stars: 7 Votes
Will adding a slope arrow on the floor do the job? If not, try el dados' tutorial on complex floors and slabs
http://www.revitcity.com/tutorials/complex_slabs/
The sidewalk will be a roof instead of a floor attached to a mass. The path for the mass will be patterned after a split toposurface converted into a mass. Finish the roof with concrete or any finish you like and make the lines invisible using the pen tool.
I think there is also a family on the downloads section, a slab that slopes, just download that but I haven't tried using the family yet.
HTH
Extruded Curbs, sidewalks on grading
Tue, Jul 4, 2006 at 2:15:41 PM
driveways and sidewalks
Thu, Mar 20, 2008 at 2:45:37 PM
CURBS AND SIDEWALKS!
Fri, Feb 11, 2011 at 11:58:44 AM
Grade Hatch in Elevation
Wed, Aug 6, 2008 at 12:03:16 AM
Wall finishes and grade
Tue, Aug 31, 2010 at 12:33:10 AM
Page generation time: 0.3400
