Forums >> Revit Building >> Technical Support >> Make a new wall function
Thu, Mar 20, 2008 at 12:09:04 PM | Make a new wall function
johnalgeo
Revit  Architecture 2008.  I want to create a wall function to existing so I can export it out to Autocadd on Layer 14
So existing walls export to layer 14
New wall export to layer 2.
Thanks,
 JSA
john a
Thu, Mar 20, 2008 at 3:38:47 PM | Make a new wall function
From the export menu, click on options, then layer settings.  If you pull down the scroll bar it apperas that all Existing is mapped to -EXST colr 3 for both cut and projection.  I've not had to do this yet but change the mapping here and see what happens.
Thu, Mar 20, 2008 at 6:41:47 PM | Make a new wall function
johnalgeo
Yep that worked.  All the existing objects where exported to S-Col-Existing A-Wall-Int-Existing etc.
 Thanks,
 JSA
john a
Wall & Floor Assemblies - Function Field
Mon, Sep 29, 2008 at 1:28:21 PM
Wall Function - WTF??
Wed, Nov 21, 2012 at 12:17:24 PM
Copy/Monitor function
Wed, Jul 8, 2009 at 4:50:14 AM
Wall Function Parameter and Roof Tags
Tue, Jan 30, 2007 at 3:21:29 PM
detail line chain function lost
Mon, Aug 10, 2015 at 10:35:56 AM
11
Page generation time: 0.8577
