Forums >> Revit Building >> Technical Support >> Formulas in Tags
Thu, Mar 20, 2008 at 11:08:07 AM | Formulas in Tags
twhisker
2.5 Stars: 5 Votes
Hey all - having some issues with creating a formula in tags.  Not sure how other firms operate.  In CAD, our casework is 32 1/2" high plus 1 1/2" for countertop = 34" high surface.  We would put 34" in the casework tag because it was the end result and included the countertop.  In all of it's exactness, Revit cannot do that.  the casework is 32 1/2 and the countertop is a seperate object.  I am looking for a way to put a formula so the height shows up as 34 and not 32 1/2" other than creating a sepearte "dummy" field that we would have to fill in all the time.  Any ideas??  Thanks.
Revit Architecture 2010
Thu, Mar 20, 2008 at 12:22:04 PM | Formulas in Tags
I think you should be able to have a calculated value for a paramter in the family that is then listed in your tag.  Look at adding the counter thickness to the offset off the floor.
Understanding Formulas
Tue, Nov 16, 2010 at 1:36:05 PM
14
to import shared parameters with formulas.
Fri, Jun 20, 2014 at 7:19:05 AM
Room Tags That Calculate [ 1 2 ]
Mon, Feb 17, 2014 at 3:28:45 PM
22
Parameter Formulas
Wed, Mar 21, 2007 at 12:48:43 PM
Tags, Labels, Formulas and Parameters
Sat, Feb 24, 2007 at 8:55:09 PM
Page generation time: 0.1198
