14 Users Online (12 Members):
Forums >> Community >> Newbies >> Which to use ACA or Revit Arch
24 Posts No Rating |
I m newbie and cant decide that in which software among ACA ARch & Revit I sud start work. Please let me know the advantages & Disadvantages of both Thanks
Why don't you try both and then decide what it's more easy and better to work...
I'm new to Revit but... I took a look at both ACA and Revit. For me it was the fact that your model is linked to your elevations, sections, details, wall types, schedules, etc so everything changes in real time AND every review from a current user i saw said they would never go back to ACA. I'm experiencing a learning curve with for example creating families but i just think i have to get through it because once i'm proficient at creating new families......elevation, sections, 3d, etc etc will be started or done already. Revit may be the way of the future. Because most everything is linked, you are assured greater accuracy. Revit makes many common mistakes impossible, such as having details reference the wrong sheet. Search this forum for more answers to your question and also see Autodesk white papers and brochures, try the trial versions (i did), check out some of the videos at other sites. good luck. let us know what you do. John
I have a Strange problem that During installaton of RAC 2008, Templates & Cabinet fies are not installed and Give an error, can u tell me how todonwload only "REQUIRED" Template & .Cab file. Pls also name them.
"Wall Modifier" |
Fri, Jun 12, 2009 at 8:09:00 AM
ACA Curtain Walls vs. Revit |
Sun, May 4, 2008 at 8:20:27 PM
ACA vs Revit? |
Tue, Apr 3, 2018 at 8:40:44 AM
Cannot see arch object when model is linked into revit structure from revit arch |
Fri, Jan 22, 2010 at 9:58:53 AM
11
arch viz-revit or max |
Mon, Jul 20, 2009 at 12:00:58 PM
