19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Rotating textures
43 Posts No Rating |
I can't seem to figure out how to rotate a texture. For example, I have a floor with the hardwood flooring texture applied, but in plan I need it to run 90 degrees to what it is showing. Anyone know how to rotate it?
Thanks
----------------------------------- -IOeser |
Go to settings-->Materials-->locate the material-->Select Accurender arrow to go to the accurender properties...
Select Material-->Edit-->Click Maps tab-->Select the map under image mapping...
Select Edit-->Click the Orientation tab-->Then change the rotation...
This is providing the texture is using a map...
Let me know if its been done using an accurender procedure...
HTH.
free hi res textures |
Mon, Apr 13, 2009 at 2:47:29 AM
Revit render textures - any good resources on the web? |
Thu, Dec 16, 2010 at 10:54:15 AM
adding textures to wall |
Tue, Oct 17, 2006 at 9:27:46 PM
Rotating Symbol geometry without rotating leabel |
Wed, May 6, 2009 at 8:33:58 AM
High Res Textures for Rendering |
Fri, Apr 17, 2009 at 12:15:29 PM
