21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Family matter
Hi there Maybe it is trivial but not to me, can any one explain? What are the 0 dimensions for and how you create them? (Attached a image of the 0 dimensions in a door template family) Nirim
I use 0 dims sometimes to keep a reference plane on the face of a wall, or if I'm not using reference planes, to keep the faces of two objects together. It can sometimes be faster than using a locked constraint, but it depends on how you build your family pieces.
Ruth Rau Main Street Architecture, P.C. |
kesflower Tanks’ for that but how do I create the 0 dimension? Or I do I do I measure 0 distance? nirim
Sorry for screwing up the sentence. It is supposed to be ‘Or how do I measure 0 distances? nirim
You create a 0 dim the same way you create any other dim. Just make sure that the witness lines are actually touching the elements you want to dim. If its not showing up, check your Visibility/Graphics settings to make sure that dims are showing up at all. you can also check in your Project Unit settings to see if everything is as it should be there.
Good morning kesflower Thanks nirim
In place family export/ copy |
Fri, Jul 23, 2010 at 10:42:07 AM
Beam not showing in Plan View no matter what I try |
Thu, Nov 5, 2015 at 4:29:31 AM
Section Head Color Won't Change No Matter What! AAAAARGH! |
Tue, Mar 13, 2012 at 5:01:01 PM
need help with family |
Mon, Nov 13, 2017 at 7:33:31 AM
Fixing a door frame, no matter(almost) the wall thickness |
Fri, Feb 24, 2017 at 8:56:08 AM
