17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Add rotate parameter by roof pitch not degrees
I have created an exposed rafter tail and i am curious if we can place a parameter that we can say type in 3:12 for the rotation. right now we have degrees and if our roof is say 4:12 then we have to calculate it and type the degrees in to 18.43. PLMK. ThankS, Lorne
Denver, CO
Revit Architecture |
Anybody? Is this possible? It would really be helpful to place in our family, because we indicate roof slopes by 3:12, or 4:12, etc. Not Degrees. Thanks
Denver, CO
Is this a family element or do you just want to know how to rotate it in elevation?
Family element. I have created twofamilies that need to have the slope of roof specified. One, is an exposed tapered rafter tail that needs to obviously bet the same slope as the roof. Two, we have created a trapeziod window that we need the top of the window to run parellel with the roof slope above. Make sense? It's not in elevation. It's a parameter from the family.
Denver, CO
Did you try creating a parameter that uses a trig function conversion . See the attached simple family example. Dan-o
That is EXACTLY what I needed. Thanks so much Dano  Lorne
Denver, CO
you're welcome lorne17. I just wanted to tell you that I've taken a visit to your firm's website. Very nice work you're doing down there in Texas!!!
Thank you Dano, We appreciate that. I'll be sure to pass that along. Lorne
Denver, CO
another double pitch roof question! |
Thu, Jun 14, 2007 at 10:42:50 AM
Adding PITCH to a Curved/Barrel-Vaulted Roof |
Thu, Feb 21, 2008 at 8:21:25 PM
Duel Pitch Roof |
Tue, Feb 10, 2009 at 2:11:10 PM
Bay window roof pitch |
Fri, Apr 7, 2006 at 1:01:50 PM
can't change roof pitch |
Wed, Mar 18, 2009 at 9:47:54 AM
