Forums >> Revit Building >> Technical Support >> Radiate material problems
Tue, Mar 18, 2008 at 2:53:38 AM | Radiate material problems
Rasmus
Hi everyone..
 I have som problems with Radiate.. When i radiate my drawing, one a few materials apear.. Some trees and some water, but all the other material doesn't show!!
 What is wrong? what can i do?!
Rasmus
Tue, Mar 18, 2008 at 5:06:16 AM | Radiate material problems
4 Stars: 205 Votes
Radiate it's proprely to interior renders, when you talk about "Trees..." i supose you are trying to render a exterior scene, but, when you radiate you must click several times in "continue" until your "Residual" is low "e.g. 0.15 or 0.10", then after you radiate your scene you can Render and everything it's ok....
Tue, Mar 18, 2008 at 7:22:23 AM | Radiate material problems
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
Yes, rendering is completely seperat from radiating. Once you radiate, render and your materials will show up in full.
Brandon Pike | Owner/BIM Specialist
cad.web.print
website: http://www.thinkdesign-studios.com
blog: http://www.bimtionary.blogspot.com/
Tue, Mar 18, 2008 at 9:11:34 AM | Radiate material problems
Rasmus
Okay.. thanks a lot, but i still dont really get what radiate is then?
can you explain it simple?
And the material didnt show, because i moved the project, and not my custom materials ;-)
And thanks for your help!
Tue, Mar 18, 2008 at 2:40:45 PM | Radiate material problems
Rasmus
i have a problem with Radiate..
When i Radiate, the light looks wierd.. the light on the floor looks good, but on the walls and ciling it doesnt!
You can se the picture..
 Anyone know what to do?
 Rasmus
Tue, Mar 18, 2008 at 2:42:37 PM | Radiate material problems
Rasmus
Wed, Mar 19, 2008 at 12:50:48 PM | Radiate material problems
4 Stars: 205 Votes
OK RASMUS, this problem appears several times when you don't follow some rules: 1º - you must join your walls each other and join with the floor and the celling, use "JOIN GEOMETRY and EDIT WALL JOINS".
2º - After this, you must radiate several times until your "Residual" goes to "0.10 or 0.15", it takes several hours (depend of your hardware) in Revit, if you use 3DS MAX or VIZ it's faster but in this case (Revit) you have to be patient...
Follow this simple rules and in the final you have a realistic Render... Enjoy.
Fri, Mar 21, 2008 at 2:43:32 AM | Radiate material problems
Rasmus
i will get right on it!
Thanks a lot!
Rasmus
Sat, Mar 22, 2008 at 11:56:43 AM | Radiate material problems
Rasmus
i still have some problems with this... i joined the walls and floor and ceiling, but there are still some problems with the shadows from the Sofa, its very pixilated? i dont know how to improve the shadow quality
Sat, Mar 22, 2008 at 1:01:37 PM | Radiate material problems
4 Stars: 205 Votes
Attatch the image, what's the final residual radiate?
Sat, Mar 22, 2008 at 1:54:28 PM | Radiate material problems
Rasmus
i look like the picture already atached, the residual was 0.07
Sat, Mar 22, 2008 at 1:55:00 PM | Radiate material problems
Rasmus
it*
Sat, Mar 22, 2008 at 2:04:52 PM | Radiate material problems
#13
4 Stars: 205 Votes
I don't no man, are you working with SP3 installed? with 0.07 residual must be fine, are you render with 300 Dpi?
Sat, Mar 22, 2008 at 2:35:16 PM | Radiate material problems
#14
Rasmus
wierd.. sp3? i dont hink so.. i work with Revit 2008 Architectual.. well.. thx for trying, i will work with it for some time.. And MAKE it work..
Sat, Mar 22, 2008 at 2:55:59 PM | Radiate material problems
#15
4 Stars: 205 Votes
Rasmus, Autodesk launch 3 Service pack for Autodesk products including Revit, so, you must install Revit SP3 and i think your problems are solved...
Raytrace / Radiate
Wed, Aug 1, 2007 at 3:07:00 PM
Rendering with 'Radiate'
Mon, Aug 4, 2008 at 1:29:20 PM
Radiate & Glass in Revit Architecture
Thu, Sep 13, 2007 at 9:36:34 AM
Material problems Please Help!
Sat, Apr 21, 2012 at 5:58:38 AM
Material Takeoff problems
Thu, Oct 12, 2017 at 5:53:40 PM
Page generation time: 1.4247
