19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Different room tags in different views?
8 Posts No Rating |
I want room names w/ numbers in most views, but on one plan I want to used room tags w/ area. If I change the tag type, it's changing the tags in all the views. Is there any way to do this? Or, can I create an additional tag that would giv me only the square footage (no name or number)? I would rather not create a separate area plan that I will need to keep updating.
Your thoughts are correct .... just create a new type. We have several types in our family with a visibile switch for the various parameters. You can also create a new family that looks at the same information. Good time to learn about parameters.
8 Posts No Rating |
Ok...but if I add a room tag w/ area only to the single plan, how to I get it turned off in all the other plans?
You can turn off all tags using VG. BTW - an easy way to do tags is to do them in one plan .... lets say it's architectural - window the plan - filter it for room tags - copy to clipboard - paste them in your other view (maybe furnishings ... electrical). While they are highlighted, you can change their type to the type you want.
Select room tags; copy rooms to new phase |
Thu, Jun 29, 2006 at 7:19:48 AM
Room tags in section views |
Tue, Sep 27, 2005 at 4:39:14 PM
Room Tags in RCPs |
Sat, Feb 11, 2006 at 3:03:52 PM
ROOM TAGS |
Fri, Jul 29, 2011 at 8:25:58 AM
2 views, only one room tag showing? |
Tue, Jun 23, 2009 at 2:28:32 PM
