25 Users Online (23 Members):
Forums >> Revit Structure >> Technical Support >> Reinforcing a Sloped Slab - Please Help!!
1 Posts No Rating |
I've created a concrete slab in a project and I have added slope to this slab by highlighting it and selecting the modify sub element tool and assigning an elevation to the points in which I needed sloping. After the slab was created, I used the sketch area reinforcement tool for adding rebar to this slab. When I hit finish sketch and view the slab in section I see that the reinfocing does not follow the slope of the slab. Does anyone know why this is? Does it have anything to do with how I created the slope in the slab? I have attached the file so you can view what I am explaining. Thanks
4 Posts No Rating |
I am having the exact same issue. How do I tell the reinforcing to have a start and finish elevation so it can slope with my slabs? Thank you.
----------------------------------- Life is not always linear... |
sloped foundation slab to flat slab join |
Mon, Mar 25, 2013 at 8:01:59 AM
sloped slab edge |
Mon, Mar 22, 2010 at 7:16:26 AM
Test Labels with psuedo dimension lines |
Tue, Sep 20, 2005 at 9:45:16 PM
Creating drop panels to the underside of a sloped floor slab |
Fri, Feb 12, 2016 at 9:41:01 AM
can I model a rebar inside a model slab |
Thu, Jan 10, 2013 at 12:29:27 PM
