22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> HOW WOULD I MAKE A WATER SLIDE
15 Posts No Rating |
I'm stuck on the best way to attempt doing this. I need to make a water slide with curves and drops. How would you do it? Thanks in advance.
Post edited on 2005-03-15 14:16:10
Use reference lines to create a 3D path for the slide. Then create a sweep using pick path and select the reference lines. You may need to do it in segments....
Unless its a simply one plane slide that just goes up and down in elevation its going to take some trial and error.
If you having trouble, supply a sketch and someone or i might give it a go...
HTH.
ok but it will be sometime tomorrow before i can do that. Thanks.
X, Y, Z SOLID EXTRUSION |
Wed, Jan 5, 2011 at 11:42:40 AM
how to make a slide |
Tue, Nov 18, 2008 at 6:26:33 AM
Squatting Water Closet |
Wed, Dec 7, 2011 at 11:31:34 AM
modeling body of water (2017) |
Fri, Mar 3, 2017 at 10:19:37 AM
Water Trick [ 1 2 ] |
Thu, Nov 20, 2014 at 6:01:13 AM
20
