20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Show window tags for transoms above?
In my plan I cannot see the window tags for transoms above the cut plan. Is there a way to do this? I tried to use the Tag not all taged and that didn't bring the transom ID tags up? THanks
Denver, CO
Revit Architecture |
Nevermind. I changed my top in my view range to be above the transom sill ht. Then used the 'Tag not all Tagged' and that pulled them down. Thanks.
Denver, CO
In order to tag, the family has to be in the view somehow. You will have to modify your window family adding an invisible line to the transom window that will extend down into your view range..... that is assuming your transom window is a seperate family. If it is a nested family, make sure the families are set to share.
That works too. Thanks.
Denver, CO
8 Posts No Rating |
Or, you can create a plan region at your transom windows that has a different view range than the rest of the plan.
Window tags not showing |
Thu, Sep 28, 2006 at 1:10:48 PM
Window tags & showing window #(Mark) on plan |
Thu, Nov 3, 2005 at 9:46:11 AM
Window Tags not working |
Fri, Sep 24, 2010 at 7:30:45 PM
Transfering door and window tags to Sheet File |
Tue, May 8, 2007 at 2:13:35 AM
window tags in elevation |
Tue, Feb 13, 2007 at 12:51:56 PM
