Forums >> Revit Building >> Technical Support >> Creating Objects
Sat, Mar 15, 2008 at 9:10:49 AM | Creating Objects
Bota
What is the best way to create my own objects that I want in Revit? Currently I've been experimenting with Inventor and importing the stuff I make in it to Revit but I just wanted to check to see if there was an easier or better way to do it?
Sat, Mar 15, 2008 at 10:44:17 AM | Creating Objects
coreed
coreed Avatar
4 Stars: 16 Votes
what type of objects are you talking about. revit has the family editor for making components and the building maker tools for creating mass and in-place familys/objects.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Mar 15, 2008 at 11:17:35 AM | Creating Objects
Bota
Well I was thinking about furniture mainly. I wanted to make my own beds, couches, chairs, etc.
Wed, Mar 26, 2008 at 5:47:13 AM | Creating Objects
chiragpklg
4 Stars: 11 Votes
well u can create furniture with the help of masses
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Wed, Mar 26, 2008 at 8:05:31 AM | Creating Objects
kesflower
3.5 Stars: 11 Votes
If you want furniture that you can use in multiple projects, I'd make a new family.  There are a couple of benefits to that, but the one I like most is that you can change the family remotely and then reload as needed.  You can also turn the furniture on and off using your visibility/graphics.  You can do that with masses too, but I find the set up to be a little less tedious if I just turn off all furniture families.
Ruth Rau
Main Street Architecture, P.C.
Mon, Mar 8, 2010 at 8:23:08 AM | Creating Objects
Joseph2
I am creating a train station and want a light rail train that I invented in the program "Inventor."  How do I import that train into Revit?
 Or further more, how do people create families?
Mon, Mar 8, 2010 at 9:24:52 AM | Creating Objects
TomDorner
4.5 Stars: 25 Votes
You can export out of Inventor to the new .adsk format which is a valid family format inside of Revit.  Can't remember if their is a plug-in that you need to download for this purpose in Inventor or not.  You will also need to watch the orientation of the x,y and z axis inside Inventor as they differ from the standard Revit orientation.  Check the Inventor help file for more information.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Creating objects
Thu, Nov 16, 2006 at 6:06:59 PM
Creating new revit objects.....
Sat, Apr 15, 2006 at 11:56:22 AM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:58 AM
please help- tried everything to get objects to accept material...
Thu, Apr 16, 2009 at 12:45:04 AM
Creating Labels for Family Objects
Wed, Nov 21, 2012 at 9:29:11 AM
Page generation time: 0.2349
