Forums >> Revit Building >> Technical Support >> Underlay Bug
Fri, Mar 14, 2008 at 1:49:42 PM | Underlay Bug
stang
Revit Architecture 2008
 i don't know if anyone has encountered this problem before, but my underlay option in view property is giving me some trouble.  I have a three storey building.  On the 3rd floor plan, if i choose 2nd floor as my underlay, nothing show up.  (But if I choose Ground as my underlay, it works fine.  and 2nd floor shows up fine on Ground floor plan as well).  The problem just started today, and it is very inconvenient.  I even audit the file, but it's not helping.
 Any help would be much appreciated.
Mon, Mar 17, 2008 at 8:36:39 AM | Underlay Bug
It is not a bug ... you have some of your settings wrong. Look at your VP seetings for view range. You will note that you have your Primary range bottom set at the level below and probably offset up from that. Change this to the same level you are on (associated) and offset down from there. VOILA ... your underlay will now work.
Edited on: Mon, Mar 17, 2008 at 8:37:23 AM
Mon, Mar 17, 2008 at 11:16:23 AM | Underlay Bug
stang
thanks
that does work.
Underlay Bug/Glitch when Zooming in and Out
Wed, Sep 17, 2014 at 9:36:52 AM
Underlay
Thu, Oct 11, 2012 at 8:15:33 AM
REVIT 2011 BUG OR NOT BUG?
Mon, Dec 6, 2010 at 6:28:30 PM
Underlay is not working
Mon, Apr 28, 2014 at 5:29:50 PM
REVIT 2015 - Underlay: EXPORT?
Tue, Aug 5, 2014 at 2:54:54 PM
Page generation time: 1.0623
