Forums >> Revit Building >> Technical Support >> Detail & Section Tags
Fri, Mar 14, 2008 at 10:26:35 AM | Detail & Section Tags
mhollenbeck
I have sections and details referenced to drafting views and I want to modify the tag.  Specifically, I want to be able to edit the drawing number and keep it inside the bubble.  When I try to modify it, it places the drawing number in the location of the default SIM label.  Is there a way to remove the auto drawing number for editing?  Also, on section tags, is there a way to make them display the arrows to match all the others?  Using Revit Architecture 2008
Mon, Mar 17, 2008 at 8:42:14 AM | Detail & Section Tags
Look in the help under "Section" ... "Creating a Section Head Family"
additional detail tags
Thu, Apr 19, 2012 at 3:27:31 PM
Section tag font not changing in "side" section tags
Thu, May 22, 2008 at 9:21:54 AM
plan detail callout in section
Fri, Mar 29, 2013 at 12:48:11 PM
14
Using 2d group for Wall section, section details called out from wall section?
Fri, Oct 9, 2015 at 10:50:56 AM
Two Detail Tags with Same reference Sht & Dwg
Fri, May 23, 2008 at 10:23:03 AM
Page generation time: 3.4625
