Forums >> Revit Building >> Technical Support >> annotations not showing up in link
Thu, Mar 13, 2008 at 11:50:27 AM | annotations not showing up in link
jrosenwald
i have a linked revit file that is not showing my room tags. what do i do?
Tue, Mar 18, 2008 at 3:52:14 PM | annotations not showing up in link
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Go to Visibility/Graphics, select the Revit Links tab and setup custom visibility view. You should see a pulldown to select "By host view", "By Linked View" or "Custom". If you set it to linked view it will inherit the visibility of the view you select. If you set to custom you can pick and choose the visibility of items just as if it wasn't linked.
Mon, Jul 7, 2008 at 9:27:29 AM | annotations not showing up in link
kingmall
I have the same problem. I have my VG for revit links set to custom, I have checked the room tag annotation category for both revit links and the "main" annotation tab, but none of the linked annotation elements show up! There must be something I'm missing!
what is the fastest way to turn off annotations for linked revit files?
Mon, Apr 18, 2011 at 3:33:30 PM
Demo Annotations
Mon, Jan 28, 2013 at 5:12:34 PM
Revit link not showing except in 3D
Thu, Mar 6, 2008 at 9:01:24 AM
Can't load annotations
Wed, Jun 27, 2007 at 4:23:05 PM
Structural link showing colored lines - please help!
Thu, Dec 2, 2010 at 3:32:36 PM
Page generation time: 0.2782
