Forums >> Community >> Newbies >> Showing Structure in elevation
Thu, Mar 13, 2008 at 9:23:05 AM | Showing Structure in elevation
SWentz
I’m using Revit’s structural tools to insert beams and columns.  They are showing up fine in plan and in the 3D views, but when I switch it over to elevation they only appear as a single line.  How do I make structure show up in elevation as the physical structure and not just a single line?  See screen shots attached
Thu, Mar 13, 2008 at 5:56:01 PM | Showing Structure in elevation
Debo
Change the "detail level:" to FINE and the "model graphics" to shading with edges... Hope that helps....
WALL JOIN PROBLEM - Ends showing in 3D and Elevation View
Tue, Jul 22, 2008 at 9:38:24 AM
View Name showing up in Elevation Tag
Wed, Feb 29, 2012 at 6:53:36 PM
Roof not showing all layers of sructure in some sections
Fri, Sep 15, 2017 at 1:25:04 AM
11
Window elements not showing in one elevation.
Mon, Jun 12, 2023 at 7:15:06 PM
Walls not showing up on section cuts
Tue, Feb 7, 2012 at 2:52:55 PM
Page generation time: 0.3418
