11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> In Revit Architecture 2008 How do I create a construction detail?
13 Posts No Rating |
For instance where the roof meets a wall, double top plate , sole plate, footings, concrete piers, pt mudsill, drip or gravel guard, etc. I have included a sample of a completed one but don't know how to do it. Please help. I need this to work.
create your roof, walls and foundation (footings can be a sweep attached as a integral walls weep at the bottom of the foundation wall) as model elements, cut a section and overlay detail components (eg. 2x's, cmu coursings, batts, etc.) and add text with leaders for noting.
cad.web.print website: http://www.thinkdesign-studios.com blog: http://www.bimtionary.blogspot.com/ |
I am only familiar with the first step. If you would not mind a step by step that would e very helpful. Thanks
Civil Construction Drawings in Revit Architecture 2013 |
Sun, Jan 31, 2016 at 2:37:03 AM
Exporting a walkthrough path from Revit Architecture 2008 to Autodesk Viz 2008 |
Tue, Nov 20, 2007 at 12:37:43 PM
Existing wall assembly visable in New Construction phase |
Wed, Nov 2, 2011 at 5:49:09 PM
Crashes with Architecture 2008 |
Mon, Oct 22, 2007 at 6:48:44 PM
12
Detailing in Revit |
Fri, Nov 15, 2013 at 10:27:37 AM
