15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Door Cill
I am using Revit 2008. I want to flip an external door so that the door opens out. When I do this the cill flips to inside. How can I lock the cill to outside as well as the door. regards Mark
You can check in the properties of the door and see if it was designed with a sill for both sides of the wall that can be turned on and off as desired. If not, you have to edit or duplicate the family yourself to create one that fits your need.
WINDOW CILL FAMILY PROBLEM |
Wed, Apr 11, 2018 at 12:44:13 AM
Precast Stone Window Cill |
Mon, Dec 16, 2013 at 7:42:36 AM
Problems with extrusions attached to moving work planes |
Wed, Aug 25, 2010 at 6:39:45 AM
Door Schedule |
Fri, Aug 17, 2012 at 7:07:50 AM
Door parameters not scheduling or tagging in double door. |
Mon, Sep 26, 2011 at 3:29:50 PM
