Forums >> Revit Building >> Technical Support >> Continuous footing under door openings
Tue, Mar 11, 2008 at 9:25:24 PM | Continuous footing under door openings
TesterSH
Hello!   My question is simple so hopefully there is a simple answer!
 How do you get the footing to show as continuous under the wall's door openings?
Wed, Feb 11, 2009 at 7:20:18 PM | Continuous footing under door openings
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Usually you have a slab with a perimeter footing, or stem wall the footing will follow the stem wall
Wed, Feb 11, 2009 at 11:13:16 PM | Continuous footing under door openings
TesterSH
Thanks mbsteve.  This is an old post I thought would never get a response.
My issue is with an interior LB wall (stud) with the footing added from the Structural tab of the design bar.  Actually, Revit calls it a "Foundation" then you select the "Wall" flyout and add the footing family.  It snaps to the base of the wall and moves with the wall - which is great!  However, after I place a door into that LB wall, the footing ends at the jambs of the door.  Structurally, yes, there is no load uner the opening created for the door but in reality, they footing would just get poured through.
 I guess I should just use a slab thickener at that wall but in reality, that's not how it would be done in real life for most circumstances.  I guess I'm just wondering how others solve this issue.
Thu, Feb 12, 2009 at 11:33:30 AM | Continuous footing under door openings
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Put a concrete beam under it, and fuse the slab to the beam, it may not move together with the wall.
Continuous Wall Footing ?
Thu, Aug 23, 2012 at 1:59:47 PM
13
Continuous footing off center from host wall?
Wed, Mar 29, 2006 at 11:46:48 AM
Stepped Footing
Sun, Nov 7, 2010 at 7:35:38 AM
continuous footing
Wed, Jul 15, 2015 at 12:17:37 PM
Footing longer than the wall
Thu, Oct 27, 2005 at 2:48:42 AM
Page generation time: 0.2256
