11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Massing
Revit Architecture 2008. I have created a timber frame truss as a mass. It displays correctly on the screen but when I print it out the truss is transparent.
We had the same problem. You need to make sure that the material is actually set to something (the default is transparent). If tat doesnt work then it just seems to be a bug. Basically dont create anything as a mass, use the modeling CREATE button (its actually a command). This will create an inplace family which is almost exactly the same as a mass but it allows you to place the items in catagories and sub catagories. This also seems to fix the plot issues. HTH Nick
why my massing can't not be a solid? |
Fri, Feb 11, 2011 at 8:26:42 PM
Massing |
Mon, Jun 22, 2009 at 9:18:46 AM
conceptual massing...undulating roof shape |
Thu, Jun 24, 2010 at 3:01:55 PM
Finding Massing Model |
Wed, Feb 23, 2011 at 3:54:53 PM
>>>stuck with creating massing form in revit<<< HELP! |
Fri, Nov 6, 2009 at 4:07:53 PM
