Forums >> Revit Building >> Technical Support >> column visibility issues
Tue, Mar 11, 2008 at 10:43:11 AM | column visibility issues
NancyHKA
Hey all, I've created a new column family (using the column template) and loaded it into an existing project.  Only problem is, when I go to my floor plan view, once I move the column into a wall, it's no longer visible.  I don't think it has anything to do with how high the cut plane is, since the column is the same height as the wall that's obscuring it.  Attached is a screenshot.  Any suggestions?
Tue, Mar 11, 2008 at 11:21:11 AM | column visibility issues
Jerome111
3 Stars: 2 Votes
Try using the unjoin geometry button on your tool bar. For some reason when columns embed into a wall it take the same finishes. If you unjoin the geometry it should correct the visibility.
Tue, Mar 11, 2008 at 12:08:15 PM | column visibility issues
NancyHKA
thanks jerome, that worked out well.
Visibility graphics of a structural column
Mon, Aug 16, 2010 at 8:21:00 AM
Column Issues
Wed, Feb 1, 2006 at 7:51:50 AM
column grid visibility
Wed, Nov 15, 2006 at 3:43:13 PM
Family Issues and visibility settings
Mon, May 18, 2015 at 12:39:34 PM
Column Base Plate Nested Family - GCS Visibility
Sat, Feb 21, 2009 at 9:17:59 AM
Page generation time: 2.1982
