24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> LOOKING FOR small CORNER SINK
135 Posts No Rating |
Hi all. i am looking for a small corner sink, for a toilet area, to position it in a wall corner? some one has one? grtzE
Here is one
Thnxs, E
4 Posts No Rating |
I don't know why but it doesn't work for me
Wall based family ...If you can open the file, then it will work fopr you.
Doesn't work for me either, I can open the family but when I insert it into the model I get an error "Can't make type "33988_Corner_Sink"." However I deleted the locked 0'-0" dimension off the wall and then it works, so if you are looking for a quick fix then try that.
Edited on: Tue, Feb 14, 2017 at 3:14:34 PM
jmhmoniz How do you remove that dimension?
Open the family. Go to the Ref. Level view. Select the dimension that is called "Off the Wall = 0'-0"" and hit delete.
Thank you!
Counter Top w Sink in Revit 2013 |
Mon, Mar 11, 2013 at 5:36:29 PM
Cutting countertop for sink |
Tue, Apr 15, 2014 at 5:21:32 PM
Suggestion required - Sink aperture adjustment |
Thu, Nov 19, 2009 at 9:36:36 PM
Looking for a farm sink .rfa |
Tue, Oct 1, 2013 at 3:58:07 PM
Modelling Sink - Problem |
Tue, Mar 21, 2017 at 5:00:16 PM
