11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Framing Plan and floor visibility questions
36 Posts No Rating |
Afternoon all, I've been putting together a framing plan for a project I'm working on, and I need some help. The home I'm working on has 2 stories and a basement. I've modeled in the beams and beam systems to hold up the first floor (between the basement and 1F). Because I modeled it in the 1F view, all of the 1F walls are visible in the drawing. I realize that I could turn off the walls if I wanted to, but I'd like to show the basement walls underneith instead of the 1F walls. I've got the underlay set to B1, but the lines are still to faint to see well. However, the beams arn't visible from the B1 view. See the attached drawings- the 3D image is to illustrate that the beams are modeled in the correct place, but I'd like to show them on the B1 plan instead of on the 1F plan. I'm using Revit 2008. Any help would be greatly appriciated. Thanks a lot!
Have you considered creating a reflected ceiling plan instead of a floorplan for your framing plan?
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG |
Framing Plan |
Tue, Jan 3, 2006 at 4:10:28 PM
12
Can't see Structural Framing from attached Revit Link in any Floor Plan |
Thu, Mar 8, 2018 at 3:01:11 PM
11
Walls in Framing Plan |
Fri, Dec 21, 2012 at 1:08:42 PM
Floor plan is missing in view |
Fri, Nov 4, 2016 at 10:03:46 AM
Framing Plan - Getting Walls Below Floor to Show Openings |
Thu, Jan 6, 2011 at 10:11:23 AM
