Forums >> Revit Building >> Technical Support >> associating 2d filled regions with 3d wall types
Mon, Mar 10, 2008 at 3:59:43 PM | associating 2d filled regions with 3d wall types
thankyoufrankgehry
1 Stars: 1 Votes
Hi.  I am using Revit 9.0.  My question concerns creating visually correct wall sections.  I have made some stacked walls showing the wall below grade.  However, the section cuts of my CMU blocks don't show the cavity--it just shows a lot of vertical lines.  Is there any way to create a filled region that will appear anytime I model a CMU block in my wall sections?  Thanks in advance.
 AC
Mon, Mar 10, 2008 at 5:33:22 PM | associating 2d filled regions with 3d wall types
hisdirt
5 Stars: 5 Votes
Is it safe to assume you have all the cut patterns sorted properly?
Tue, Mar 11, 2008 at 6:29:56 AM | associating 2d filled regions with 3d wall types
thankyoufrankgehry
1 Stars: 1 Votes
I am a bit confused at what you mean....(cut patterns sorted properly)
Tue, Mar 11, 2008 at 7:02:51 AM | associating 2d filled regions with 3d wall types
You are really asking for too much from the program, these details do not need to be part of the model.  There are some good tutorials on repeating details and edit cut profile that will show you how to add to and modify sections that need to be at a higher detail.
Tue, Mar 11, 2008 at 8:17:35 AM | associating 2d filled regions with 3d wall types
thankyoufrankgehry
1 Stars: 1 Votes
Tue, Mar 11, 2008 at 8:19:07 AM | associating 2d filled regions with 3d wall types
thankyoufrankgehry
1 Stars: 1 Votes
Thanks for the info....i'm kinda new to revit, and my firm isn't really trained that well at it.
AC
Tue, Mar 11, 2008 at 8:35:33 AM | associating 2d filled regions with 3d wall types
Lots of tutorials are here: also check here
Tue, Mar 11, 2008 at 8:55:11 AM | associating 2d filled regions with 3d wall types
thankyoufrankgehry
1 Stars: 1 Votes
AC
Wed, Mar 19, 2008 at 8:43:53 AM | associating 2d filled regions with 3d wall types
thankyoufrankgehry
1 Stars: 1 Votes
Thanks for the link -- But I can't access many of the tutorials--my firm really has the internet on lockdown and I can't go to any webpage with the word BLOG in it.  It is a real pain in the curse with trying to learn Revit.  I have to call up some guy in another office and qualify why I need access to the site--which usually takes about 20 minutes--talk about dumb.
-ac
Wed, Mar 19, 2008 at 2:38:20 PM | associating 2d filled regions with 3d wall types
hisdirt
5 Stars: 5 Votes
Hi again thankyoufrankgehry
From what I can understand, there is definately a way to do what you're wanting but it wont be by associating filled regions with walls. Experiment with wall layers, layer materials etc. to see how Revit builds walls and you'll discover how best to achieve the look youre wanting,
Hope this helps!
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Masking Regions and Filled Regions BEHIND 3D Objects
Wed, Aug 1, 2012 at 8:10:27 AM
Filled Regions and families
Sun, Mar 8, 2009 at 7:10:29 PM
Filled Regions on an elevation
Wed, May 25, 2005 at 1:35:38 PM
Revit 2014 Filled Regions
Fri, Jun 27, 2014 at 4:47:56 PM
11
Page generation time: 0.5768
