Forums >> Revit Building >> Technical Support >> Linked AutoCad text emergency
Mon, Mar 10, 2008 at 12:56:06 PM | Linked AutoCad text emergency
JLwerk
Hello,
I'm working in Revit Architecture 2008.
I've linked approximately 20 details from AutoCad into our Revit model.
All of the details were created using text styles, fonts, layers, colors, etc. from the previous detail. So all of these things match from detail to detail. The text is dtext, not mtext.
When I look at the drawing sheets that these eventually end up on they look fine ON THE SCREEN.
When I plot the drawing sheets that they're on. SOME of the text plots. SOME DOESN'T.
I've changed the layers of the text in some of the files and reloaded the link. This causes the text to plot on SOME of the details that it didn't plot on before but NOT others.
There doesn't seem to be any consistency to which details plot correctly and which don't other than the same details always plot right and the same details always plot wrong. Everything else in the detail (leaders, dimensions, hatches, lines, etc.) plots just fine.
I'm stumped and this set was supposed to go out this morning (my fault for not checking earlier).
Any ideas?
Thanks.
Line weight of text from linked AutoCAD files
Fri, Sep 23, 2011 at 3:12:39 PM
Autocad Text imported
Tue, Dec 4, 2007 at 9:29:14 AM
LInked AutoCAD details into Revit 2009 workset project
Tue, Jun 28, 2011 at 5:07:32 PM
AutoCAD to Revit Linking - Text & Image Issues
Thu, Dec 15, 2011 at 2:17:04 PM
Text From Autocad Link
Mon, Sep 8, 2008 at 12:49:48 PM
Page generation time: 3.9531
