Forums >> Revit Systems >> Technical Support >> Aerial Image Under Building in 3d
Mon, Mar 10, 2008 at 8:06:58 AM | Aerial Image Under Building in 3d
MWAGNER
I have Revit Architecture 2008 and would like to take my indoor soccor building and put it on my aerial and have the aerial show up when I pan around in 3d is this possble and if so how.
Thanks
Mon, Mar 10, 2008 at 2:03:56 PM | Aerial Image Under Building in 3d
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
I haven't done this so I'm not sure if it will work. We all know that if you import an image as a decal, etc. it will not show up until rendered and an imported image will not show up in 3D. Try inserting the image into a AutoCAD drawing and linking the .dwg file into revit, the image should show through and you can adjust the level offest of the .dwg as needed.
Brandon Pike | Owner/BIM Specialist
cad.web.print
website: http://www.thinkdesign-studios.com
blog: http://www.bimtionary.blogspot.com/
Revit 2009: Mapping an aerial image to topography
Thu, Jun 18, 2009 at 10:14:53 AM
Tree Mass/ Forest - Aerial View?
Thu, Aug 13, 2009 at 7:12:29 AM
Place Google Earth image
Mon, Apr 23, 2012 at 10:11:26 AM
Tracing Building Footprints of Existing Site CAD Dwg in REVIT
Sat, Nov 30, 2013 at 6:21:38 PM
Image on building
Thu, Nov 3, 2011 at 9:11:17 PM
Page generation time: 2.8001
