28 Users Online (26 Members):
Forums >> Community >> Newbies >> foundation footings
6 Posts No Rating |
I need to move the footing of our foundation down, but I can't find where to edit it. It's not in the properties. HELP!
Footings are attached to the bottom of the wall. They have thickness and width but the elevation is controlled by the bootom of the wall itself. You should probably have a look at the REVIT CADclip tutorials at www.CADclips.com
6 Posts No Rating |
or, instead of paying for unnecessary tutorials, someone could just tell you. have you tried creating a new level for the wall height? if you don't want to make a new level, right click the wall, go to element properties, and adjust the offset (this will be a negative number since you are trying to move it down) of the base constraint for the wall. the footing will follow it. also, if you google keywords like "footing" with "revit architecture 2008" or "2009," you should be able to find plenty of blogs addressing beginning issues. many of the people running the blogs are Revit consultants for firms, so they break down the steps better than some tutorials.
ELYSE, you have my bless....
Footings for Slab Foundation |
Tue, Oct 30, 2007 at 7:05:08 AM
dashed line for foundation footings? |
Thu, Feb 9, 2006 at 4:04:06 PM
Changing Linetypes in Foundation Plan |
Thu, Mar 18, 2010 at 7:18:01 AM
Foundation Schedule - no footing thickness field - help! |
Fri, Dec 2, 2011 at 10:24:44 AM
12
Wall Footings and Foundation extrusions |
Wed, Jun 8, 2016 at 7:55:54 AM
