13 Users Online (11 Members):
Forums >> Revit Structure >> Technical Support >> Typical Detail Library
3 Posts No Rating |
I am having problems saving typical details to a library and are they suposed to be saved as a view in order to use them on different projects.
83 Posts No Rating |
If they are "drafting views" use "save to Library / save views" if it is a model based detail you will need to freeze it using the freeze drawing extension from this link. http://www.extensions4revit.com/
I have heard of this before, has anyone tried it or had any luck using it in Revit Architecture 2008?
cad.web.print website: http://www.thinkdesign-studios.com blog: http://www.bimtionary.blogspot.com/ |
I have used several of the extensions and they work great. With the "freeze drawing" you can make a 2D drafting view of a 3D section and make modificatons as needed or export to a typical library.
Custom Library - Typical Details |
Fri, Jun 24, 2011 at 1:10:55 PM
Typical Detail sheets on my first revit project |
Mon, Feb 8, 2010 at 9:22:07 AM
Family- Typical Detail |
Fri, Sep 2, 2005 at 12:21:53 PM
Typical Details |
Mon, Mar 26, 2012 at 4:55:56 PM
Detail library |
Sat, Aug 19, 2017 at 11:00:10 AM
