18 Users Online (16 Members):
Forums >> Revit Structure >> Technical Support >> sloping steel roof deck problem
83 Posts No Rating |
I am working on a typical warehouse type building with 1.5” metal deck sloped at ¼:12. It appears that if I use an architectural “roof” I cannot get the steel deck profile and the deck span tags to work. If I make my “roof” out of a structural floor with a slope, all of that works just great. The problem is that all I can get from the spot elevations is the top of deck elevation because floors insert based on the top surface. I want spot elevations to be top of steel or bottom of deck. Is there any way to set up a slab so its insert is the bottom of core?
I think what i am looking for is some way to get spot elevations for the bottom of the slab. is this possible?
slope metal roof deck |
Thu, Jul 21, 2011 at 9:40:39 AM
Sloping Steel Column |
Sat, Aug 21, 2010 at 6:14:05 AM
Sloping 5/14" metal deck roof to sit on sloping OWSJ structure |
Wed, Dec 3, 2014 at 8:50:16 AM
Exposed Structural Floor Ceiling Plan |
Thu, Mar 21, 2013 at 8:30:25 AM
Roof to follow sloped structural steel |
Wed, Sep 22, 2010 at 4:11:16 AM
