Forums >> Revit Building >> Technical Support >> Sloped slabs and spot elevations
Wed, Mar 5, 2008 at 4:06:29 PM | Sloped slabs and spot elevations
luisrpv
I am working on a parking structure that has slabs that slope to drains. I need the model to be very accurate so I can use it for my detailing aswell. However when I sloped the slabs (which was very painful) I then could no longer use the dimension tools or spot dimension, which defeats the purpose. any thought, suggestions,
Thanks.
Wed, Mar 5, 2008 at 5:28:28 PM | Sloped slabs and spot elevations
hhwse
I have been doing that same thing all day and the spot elevations are working just fine.  Are you using sub-points to get your different elevations?  If not you should try it because it makes it much easier to create the geometry.
Thu, Mar 6, 2008 at 10:30:41 AM | Sloped slabs and spot elevations
luisrpv
can you please explain more in depth. I use the default points created when making a slab. I then added several points within my slab to achieve the slope. After its complete and I cut a section or create a call out I cannot dimension it or use spot dimensions. I get an  error message that states the elements are no longer parallel.
Thanks
Thu, Mar 6, 2008 at 1:18:13 PM | Sloped slabs and spot elevations
hhwse
It sounds like you are doing the same thing I am.  Here is a PDF of a section of my floor.  As you can see, I am able to get spot dimensions at the points and anywhere along the slope.
Spot Elevations on curved walls with varying height
Tue, May 3, 2011 at 5:26:46 AM
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:11 AM
Spot Elevations
Thu, Feb 19, 2009 at 12:57:33 PM
Why are Spot Elevations so unreliable?
Mon, Sep 10, 2007 at 8:50:44 PM
Spot elevations
Fri, Jul 29, 2016 at 8:01:28 AM
Page generation time: 0.1925
