Forums >> Revit Structure >> Technical Support >> Linking Models
Wed, Mar 5, 2008 at 12:45:42 PM | Linking Models
minfante
I wanted to get a general consensus on the practice of linking models.
I work in my company's structural department and use Revit Structural 2008.  We have an Architectural department that uses Revit Architectural 2008.  I'm learning more about worksets and copy/monitoring linked models.  Is it best to practice using two separate central files, one for arch., one for struct. and have local user copies for each team member to work within?  Do I understand correctly that we (structural) will link their architectural central file and use as an underlay?  Will all of our elements be created from within our structural model?  Or can we use elements from the architectural project for our model?
Wed, Mar 5, 2008 at 2:47:40 PM | Linking Models
coreed
coreed Avatar
4 Stars: 16 Votes
maybe some of this info from AU 2007 maybe of interest to you
HTH
Edited on: Wed, Mar 5, 2008 at 2:59:26 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Mar 5, 2008 at 3:00:30 PM | coreed
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting coreed from 2008-03-05 14:47:40
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Mar 5, 2008 at 3:22:34 PM | Linking Models
minfante
Thank you.
I'll read into that, it was very helpful.
Linking Other Models
Tue, Aug 31, 2010 at 1:35:54 PM
Linking the Autodesk Advanced Models Together
Mon, May 19, 2014 at 2:02:04 PM
Linking models with multiple sites
Wed, Dec 6, 2017 at 9:43:09 AM
linking models into models
Fri, Aug 24, 2007 at 12:55:28 PM
linking models via origin to origin problem
Wed, Sep 30, 2015 at 10:20:09 AM
Page generation time: 2.1564
