13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Removing Imported Categories
22 Posts No Rating |
Found this question was asked before, but no resolution..... Is there a way to remove "Imported Categories" from a project or template? Gets tiresome seeing the same obsolete categories in every job.
Just go to Settings: Object Styles: Annotation Objects or Imported Objects: select the subcatagory and delete it. HTH Nick
0 Posts No Rating |
Is there no way to remove the imported object itself, only the subcategories?
Look at Autodesk Model checker or Ideate Explorer.
Try purging the template then uncheck all and then find what you need to remove and check those.
0 Posts No Rating |
Thanks guys, I had this same problem today. However, even Purge Unused didn't show the rogue DWG!
Turned out you need a Revit addin to remove the imported category (type) directly. I tried different ones and only Dwg Explorer could do it. Others only work on imported instances.
This simple feature should have been part of Revit already!
Annotations accidentally snapped into linked dwg (Imported categories) |
Tue, Jul 9, 2013 at 5:53:11 AM
Removing categories from Graphic Overrides |
Mon, Jul 14, 2008 at 6:58:05 PM
Delete imported categories |
Tue, May 23, 2017 at 10:26:44 AM
Removing Imported CAD file from Visablity Graphics |
Mon, May 15, 2017 at 2:12:28 PM
Removing Parts of and Imported View? |
Thu, Jul 3, 2008 at 9:55:20 AM
