Forums >> Revit Building >> Technical Support >> Need help on elevators for multi-story bldg....
Tue, Mar 4, 2008 at 1:40:28 AM | Need help on elevators for multi-story bldg....
ireyes
3 Stars: 1 Votes
I've downloaded this elevator family object from revit city, but I have one question posted below.  could anyone help?  here is the link that i've downloaded the family object from:
 http://www.revitcity.com/downloads.php?action=view&object_id=4116
How do I show this same elevator core/shaft to have a opening on every level on a multi-story building without having to place this one elevator family object on every level?  Because I have a section that cuts through the elevator core/shaft and it shows more than one elevator in the same core/shaft.
thanks,
ireyes
p.s. I'm using Revit Architecture 2008 student version
I. Reyes
4th Yr. Architecture Student
Illinois Institute of Technology
Revit Architecture 2009
Tue, Mar 4, 2008 at 2:29:14 AM | Need help on elevators for multi-story bldg....
dianajohn
What you need is a family that has doors & indicators as 3D models & the elevator car as a 2d detail.
Send me a Email at john.aitchison@projectservices.qld.gov.au and I"ll sed you a family that should do the job for you.
Best of luck John A
Fri, Mar 7, 2008 at 9:23:17 AM | Need help on elevators for multi-story bldg....
JFK64
Hi
Basically I've used the Elevator (Cab & Shaft 3D Family and extended it from "Bottom to Top"Winking Family and then at each floor I insert Elevator Door Family. I have doors and a signle cab per shaft, in section and I see the cab in every floor plan (basically I beleive your height has to be at the top most level).
HTH
John
Fri, Mar 7, 2008 at 11:41:03 AM | Need help on elevators for multi-story bldg....
ireyes
3 Stars: 1 Votes
I've tried that solution, like you said you'll get a cab in every section.  But I'll just have to live with that......
Thanks,
I. Reyes
Mon, Aug 29, 2011 at 4:23:52 AM | Need help on elevators for multi-story bldg....
ElevatorRevit
ElevatorRevit Avatar
4.5 Stars: 2 Votes
Hi,
for the next time you can also download Elevatorarchitect, a plug-in to easily create elevators inside Revit. After selecting the elevator you need it will show the elevator on every level. It shows the overall depth of the car and car doors on each level. A detaild representation of the car and doors are available on the lowest floor.
You can download it for free at http://www.digipara.com/DownloadEARevit.aspx
Karin
Can't change depth of landing in component multi story stair
Thu, Jan 9, 2014 at 8:00:18 AM
Getting Started with the project and inserting Elevators
Fri, Aug 26, 2011 at 7:52:12 AM
Editing Multi-Level Building
Wed, Jul 20, 2011 at 11:11:04 AM
Why do revit stairs still suck
Sat, Dec 22, 2018 at 12:34:36 PM
First Time Multi-Bldg Site
Fri, Nov 30, 2012 at 7:38:45 AM
Page generation time: 0.0628
