27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Room Name w/ manually entered Ceiling Height
35 Posts No Rating |
I'm trying to create a room tag with the room number on top and a ceiling height which I will manually enter on the bottom (shown attached). I started with a room tag and created a shared parameter called ceiling height. Back in my template I went into project parameters and added the ceiling height parameter. In the project parameters options I have tried to check catagories of ceilings only, rooms only, and both ceilings and rooms. Back in the file if I click on a room and go to properties there is an option to enter ceiling height, however this ceiling height will not show up in the tag and I can't type it directly into the tag. Can anyone think of anything I'm doing wrong? Any help would be greatly appreciated! Thanks in advance!
When you are adding the projewct parameter, make sure you select shared paramter and not project. A project parameter cannot appear in tags but a shared can. I tried your tag and was able to get it to work adding a shared parameter to the project. HTH,
It's still not working for me. In my template I have gone to settings-->project parameters. Once in the dialog box I selected shared parameter and checked the categories of ceilings and rooms. After I do this, ceiling height shows up as a parameter when I click on a room and go to properties, but when I fill it in and try to place the tag the bottom half of the tag is empty. Any ideas?
I just figured it out. I need to pick RCP room tag with area. I'll have to rename it to be room tag with ceiling height. Thank you so much for your help!
5 Posts No Rating |
Callie, have you really managed to place Ceiling High in a Room Tag? I´m new in using Revit, began with the 2009 and didn´t manage to do that, didn't find the RCP tag you told. Can you help me? my e-mail is jmfeitosa@gmail.com thanks
Room schedule with ceiling height |
Thu, Jan 18, 2007 at 3:46:21 PM
Ceiling height in Room Schedule |
Sun, Apr 5, 2009 at 12:44:47 PM
Add Ceiling Height in Room Schedule |
Mon, Nov 19, 2012 at 9:38:54 AM
locking height of family to ceiling height? |
Mon, Apr 27, 2009 at 5:29:03 AM
Ceiling Height in Room Tag? |
Wed, Sep 10, 2008 at 7:04:19 PM
