Forums >> Revit Building >> Technical Support >> Calculated Values
Mon, Mar 3, 2008 at 11:01:17 AM | Calculated Values
gozling
Okay I'm using Revit 2008
Does anyone know of a way to use the totals to create a calculated value rather than every instance? I am working on an Urban Design project and I am trying to use a floor schedule to create an FAR schedule.  So I have the floors of the building with an occupancy and then I have floors that give me the area of each Parcel.  I have sorted the occupied floors by giving each a cost and then creating a calculated value based on that cost and I did the same with the parcel area.  The problem is that by doing that I am dividing zero by something or dividing something by zero because it is not using the total it is using each instance.
This sounds pretty confusing so let me know if you need any more info.
Calculated Values in Room Tags
Wed, Mar 30, 2011 at 4:08:03 PM
Calculated Values
Mon, Mar 20, 2006 at 12:58:54 AM
Calculated Value
Mon, Dec 13, 2010 at 4:46:58 PM
Schedule totals are not calculated right: 1+1=1 [ 1 2 ]
Tue, Apr 21, 2015 at 1:27:21 PM
17
using schedule keys, shared parameters and calculated values in schematic design
Tue, Mar 6, 2007 at 1:41:36 PM
Page generation time: 0.0397
