15 Users Online (13 Members):
Forums >> Revit Structure >> Technical Support >> Weather Ledge, Drip Ledge, Sheeting notches? HELP!
11 Posts No Rating |
Is there a way to put a weather ledge or sheeting notch into a slab? Some people call them drip ledges. It's just a notch in the slab around the edges that go down 1.5" into the slab and 9.5" from the edge of the slab. I'm a newb to REVIT. I've always used ACAD, always loved ACAD. This problem is the main reason our company hasn't copmletely changed over. Thanks!
i use CAD since 1989, so, for me is a new world too, you can do what you want by "MODDELING>HOST SWEEP>FLOOR SLAB EDGE" or if you have a roof by "ROOF GUTTER", Revit have some gutter files but you can create or edit an existent file and change them just like you want... see the help menus...
So I have to create the slab smaller so when I add the edge, it is the correct size, right? What if all sides aren't drip/weather ledges? Doing this makes all the edges have the same drip/weather, not just the one or two edges that I needed. Not only that, what about the corners? Will it connect the corners or just leave emply aquares? I'll play around with it when I have some free time.
I created these edges, pretty easy to use If anyone needs them. Just look for Slab edges
Why won't my brick ledge show in plan |
Tue, Dec 18, 2018 at 4:46:09 PM
Brick Ledge? |
Wed, May 18, 2011 at 10:11:35 AM
Wrap wall finish to window ledge finish |
Wed, Sep 21, 2011 at 2:57:36 PM
Creating a Ledge? |
Tue, Sep 29, 2015 at 9:29:11 AM
Adjust Brick veener to move down agianst the brick ledge. |
Thu, Jul 26, 2018 at 2:23:13 PM
