9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> display edges and openings above the cutting plane in a dash dot dot linestyle
1 Posts No Rating |
HI, I need advice, how to display edges and openings in slab in a plan above the cutting plane in a dash dot dot linestyle in revit 7.
thanx.
Underlay a level showing the slab in your plan you wish to show the dash dot lines...
Once its visible, use the linework tool-->set to dash dot line and pick the edges you wish to show.
Then turn off the underlay and there you go. These lines are now associated to these edges and will move with the slab above (and vice versa). If you edit the sketch and any of these lines are deleted in the sketch you will lose your dash dot lines and will need to be redrawn...
HTH.
Fire Rated Walls Plan |
Tue, Nov 6, 2007 at 10:57:30 AM
Linestyle Display Issue |
Tue, Jan 25, 2011 at 8:57:09 AM
Howdy! I'm new! |
Wed, Apr 14, 2010 at 1:29:56 PM
Fire Resistance/Wall Hatch |
Fri, Feb 18, 2005 at 11:08:09 AM
Dimension with Tick and Dot |
Fri, May 21, 2010 at 10:36:20 AM
