Forums >> Revit Building >> Technical Support >> 'PAD' slope
Fri, Feb 29, 2008 at 5:22:52 PM | 'PAD' slope
CadMasterAdam
So why is it that i can't apply a simple slope to a 'pad' object in the site menu bar?
I need pad and not floor.  Floor objects don't cut through topography.
suggestions?  I've reivewed the "complex slab" tutorial from eldados circa Nov. 18th 2005.  However i hope 3 years of development by AutoDESK would have generated a simplier solution.
thanks!
Sat, Mar 1, 2008 at 4:37:38 AM | 'PAD' slope
4 Stars: 205 Votes
Hi, when you create a PAD it's just like a kind of "HOLE or BASE", there aren't no slope in there (for yet), if you need a slope in your topography site you must create them by "Toposurface" with elevation points.
Mon, Mar 3, 2008 at 9:54:29 AM | 'PAD' slope
CadMasterAdam
well thats tedious.
Thanks Revit Team!  I mean its not like no one ever has a subgrade pad with a slope on it.  That never happens.
Mon, Mar 3, 2008 at 10:58:29 AM | 'PAD' slope
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
You can create a SLAB from the STRUCTURAL MENU and apply slopes and dips and humps etc. to it, assign a site material to it and see if that works for you.
cad.web.print
Mon, Mar 3, 2008 at 11:22:17 AM | 'PAD' slope
CadMasterAdam
I'll try the slab in the structural menu.  does the topography cut around the 'slab' as it does the 'pad'?
Thanks Typhoon
Mon, Mar 3, 2008 at 12:48:52 PM | 'PAD' slope
4 Stars: 205 Votes
You welcome, you can create a "SLAB" and put slope in that, but, your topography can't cut around the slab, you must do what i tell you before, create a "PAD" around your model, then give them elevation, that's the way you can cut the site , maybe in the next RAC 2009 they resolve this situation...
Mon, Mar 3, 2008 at 12:54:09 PM | 'PAD' slope
CadMasterAdam
Sigh
Thank Typhoon, will do.
Roof's wont slope :(
Mon, Apr 2, 2007 at 5:34:05 PM
slopped pad
Fri, Jun 23, 2006 at 9:42:32 AM
Stair stringer slope doesn't match riser slope?
Fri, Aug 21, 2015 at 10:30:14 AM
pads and phases
Mon, May 22, 2006 at 1:20:40 PM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Page generation time: 1.8598
