13 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Ramp won't show cut in plan view...
2 Posts No Rating |
Hello, I have a building with a ramp extending from level 1 to level 3 of the building. When I look at the ramp in plan view, it will not cut at the cut plane. In my Object Styles dialogue box, it says that ramps above the cut plane should be shown with an overhead dashed line. I want them to appear just like a set of stairs, with a solid line below and a dashed line above the cut plane. I have the Object Styles set up the same for stairs and ramps, but no matter what I do I can only see the ramp in its entirety with a solid line. the stairs are working exactly as I want them to. Any ideas?
2 Posts No Rating |
Well I finally fixed this issue by just applying a masking region over the portion of the ramp that I wanted to be dashed and overriding its graphics style. Then I added a break line detail component. If anyone had any input as to why the ramps don't work like the stairs in this case I'd love to hear it....
Can a ramp be cut in plan view? |
Thu, May 3, 2007 at 5:28:29 AM
elements won't be deleted |
Wed, Aug 8, 2012 at 9:11:31 AM
Wall Section won't show in both plan and building section |
Wed, Jan 29, 2014 at 6:52:25 AM
Imported Component won't show up in plan view. |
Thu, Aug 30, 2012 at 12:49:26 PM
Wall won't show in North elevation |
Thu, Oct 9, 2014 at 12:21:15 PM
