Forums >> Revit Building >> Technical Support >> Overlaying Hatches REVIT 2008
Thu, Feb 28, 2008 at 4:44:43 PM | Overlaying Hatches REVIT 2008
DTCesarz
DTCesarz Avatar
5 Stars: 4 Votes
Regarding hatches; is there a way to import 2 or more hatch schemes into one?  I would like to have in my cut pattern a concrete hatch as well as lines spaced @ 14'-0"... In my current solution I keep my concrete hatch in the cut pattern and overlay a filled region for the panels.  Problem is that the way I'm currently doing it interferes with my line weights (not a ton, but I'm anal).  I know there was a prev. thread of this, but it does not explain whether a combined hatch was made in a txt program. Thanks.
Wed, Mar 5, 2008 at 2:00:52 AM | Overlaying Hatches REVIT 2008
hugh
3.5 Stars: 4 Votes
Patterns can be defined as text files as described in the example pattern collection file named revit.pat. Search for that file and copy the file to (say) MYPATS.PAT to work on - the actual name doesn't really matter but .PAT works well as a  filename extension. Open MYPAT.PAT it with a text editor such as Notepad or PSPad and read the descriptive information in at the top of the file.
To extract the concrete pattern, delete everything above the line
    *Concrete,  Cut concrete
Then delete everthing from the next pattern name (*Earth??) to the end of the file.
Then add this line for vertical lines 14' apart
90,0,0,0,168
 or this line for horizontal lines 14'apart
 0,0,0,0,168
or,, for diagonal lines,
45,0,0,0,168
etc.
This will be a ;%TYPE=DRAFTING pattern
Change the pattern name at the top of the file to whatever you want e.g.
*Concrete14, Concrete with 14' lines
Save the file and load it to Revit via Settings>Fill Pattern dialog
Hugh Adamson
Cadro Pty Ltd
www.cadro.com.au
Hugh Adamson
www.hatchkit.com.au
How To Turn Off Hatches
Mon, Feb 11, 2008 at 3:27:14 PM
Autocad Hatches
Wed, Sep 19, 2007 at 8:05:47 PM
Hiding Hatch Patterns
Fri, Aug 28, 2009 at 7:32:26 PM
Material hatches
Wed, Feb 22, 2006 at 1:49:20 AM
Revit 2013 Printing Misssing hatches
Fri, Jul 20, 2012 at 9:33:46 AM
Page generation time: 2.2040
